05-12-2012, 03:27 PM
I recently invested in Lexia 3 and have used it on a Lenovo netbook. I tried to change the Eco Mode timeout. This is shown on Lexia as
00000000030. I guess this means 30 mins. I tried changing it to 60 minutes by changing the 3 to a 6. But how do you save a change. There are a number of "buttons" on the right of the screen. The top one looks like a carriage return sign (left arrow with vertical bit on right). Under that is an icon which definitely means return to the previous screen, but does it save what you have changed? I also tried turning Showroom Mode ON but the same thing happened. I made the change, as I thought, but when I opened the page again it was set at OFF. I did all this in BSI/Configuration/Manual configuration, then tried again using BSI/Configuration/Manual configuration with assistance. Same result. Is there some part of the system which prevents changes to these parameters?
alut:
