Threads: 6
Thanks Given: 1
06-12-2012, 05:18 PM
(This post was last modified: 06-12-2012, 05:18 PM by Flykiller.)
Hi all tried to set the clock time to correct time. read the part where you press button and turn it clockwise ect.. Well I tried that and a lot more ways too! still no joy. Its not a big deal just a little annoying. So if anyone can shead light on this I know it will be on here. So any suggestions??
Threads: 41
Thanks Received: 31 in 28 posts
Thanks Given: 16
Do a search. Its been covered before
Sent from my ST21i using Tapatalk 2
Threads: 6
Thanks Given: 1
Great Stuff Thanks Guys. Sorted :-)
Threads: 6
Thanks Received: 23 in 21 posts
just done mine 2002 berlingo 1.9d with the little lcd panel in the speedo.
turn ignition on . hold in the button in the rev counter till the hours flash, release and repeatedly press button to change hours, release and wait , minutes flash...press button repeatedly to change minutes. release the button when finished.
The following 1 user says Thank You to ricc for this post:1 user says Thank You to ricc for this post
• whitebus
