Threads: 50
Thanks Given: 743
06-12-2012, 09:43 PM
(This post was last modified: 06-12-2012, 09:46 PM by Ol'Jeffers.)
The warning originates, I think, in the BSI unit.
If you have a repeated warning of the door open when it
is closed, check the door latch switch.
If this is then case then you will also not be able to lock the doors
when outside the car, using the remote control.
