Threads: 5
Thanks Received: 3 in 3 posts
Thanks Given: 5
Is there an easy way to tell which caliper and disk is fitted without removing them?
ECP list 4 different varients of front caliper. one is solid but the three vented ones seem to be very minor differences - in one case looks like a 1mm difference is disk thickness.
2.0 hdi, partner, 53 plate if that makes a difference
Thanks Given: 188
23
Take the wheel off and have a look on the caliper they usually have the makers name cast into them ie bosch on mine. Then see if you have vented or dolid discs and then measure the diameter I think from memory that there are 2 sizes 266mm and 283mm dia. Also if you have abs I think that makes a differance to.
Hope this helps.
Are we there yet?????
• blob
Threads: 32
Thanks Given: 18
Yours are 266mm vented discs.
Threads: 5
Thanks Given: 5
Thanks Guys.
They are indeed 266mm vented. That still leaves two choices but looks like the 22mm thick disk version.
(there is a 22 on the caliper)
