  • 6 Vote(s) - 2.5 Average
Comms 2000
The comms 2000 unit on my van is giving an intermittent air bag light and since the indicator stalk is a bit floppy it's due for a change.
Is this a straight swop or is some form of reprogramming necessary?
Cheers, Tubby
Hi, as long as it's the same number you are replacing it with then there's no programming. Confusedalut:
  • Tubby
Cheers Rustscat,
Just seen one on Ebay but as it's from a later van can't be sure it'll be a direct replacment. May as well wait until it fall apart completely or fails the MOT, currently airbag lights are just advisories. According to the garage there's no legislation in place that makes an iffy airbag warning light illegal so it can't be a failure. Just hope they take 20 years of so sort it!!!
All very confusing.....
Tubby
The a/bag light comes on with the pre tensioners aswell.
It's usually the connectors on these that require unplugging/plugging to clear the fault. Confusedalut:
  • ron
(09-12-2012, 09:29 AM)Rustscrat Wrote:  The a/bag light comes on with the pre tensioners aswell.
If you have a friend with a Lexia, you can tell the airbag ECU that the driver's wheel airbag is not installed. This makes ECU only test the passenger airbag, and the airbag light go off as it should, and stay off.
I know this as I have Lexia and a faulty airbag/comm 2000.. ;-)
Hi rhd berlingo mutlispace 16 petrol 2003  year comms 2000 problem car
right hand drive in spain  are the lhd comms units the same straight swap any help welcomed thank you
I think they're the same and need no coding so easy to try
thanks will check with Citroen tomorrow ,garage has tried  new and second hand unit, lights, indicators fog lights all fixed, but van will not start
The antenna for the transponder chip is looped.around the key barrel. It connects to the comm2k board and then the code is sent to the BSI by the canbus link. Was it starting with the old comm board? If yes, they've not connected the antenna loop up or there's a break in the canbus wires (red/white twisted pair or pink/white). Usually a pink wire hoop for the transponder pickup.
Did you recently change the key battery by any chance?
(01-09-2022, 08:29 PM)Zion Wrote:  The antenna for the transponder chip is looped.around the key barrel. It connects to the comm2k board and then the code is sent to the BSI by the canbus link. Was it starting with the old comm board? If yes, they've not connected the antenna loop up or there's a break in the canbus wires (red/white twisted pair or pink/white). Usually a pink wire hoop for the transponder pickup.
Hi Zion ive been using the normal key not the remote locKing and unlocking by the barrel remote key  broke
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
