Threads: 9
Thanks Received: 4 in 3 posts
Thanks Given: 2
The rear wiper on my car doesn't work. I checked the two feed wires, and one was live and the other dead when the rear wiper switched on. I would have thought they would both be live as one is for the feed and the other to park when feed removed?
Well, I had a look at the fuses, and where indicated in the Haynes manual - there is no fuse (#25 on the cabin fuses). Have put a 20A fuse in there and it makes no difference.
So, any advice? By the way, the wiper is parked out of position.
If I need to replace - what other cars have the same motor? Saxos? Xsaras?
Threads: 19
Thanks Received: 18 in 11 posts
Thanks Given: 21
mmm, ours failed fairly on in our ownership and the motor had to be replaced. think it cost the warranty company over £100 :-(
Good luck, must be a shared unit with ( many?) PSA cars if not other makes too?
Threads: 25
Thanks Received: 235 in 131 posts
Thanks Given: 44
12
thowman.
How much rear doors in Berlingo? One or two?
Threads: 9
Thanks Given: 2
Single door. I haven't seen any twin door Multispaces in the UK, however all the ones I saw in Spain have 2 doors....
Threads: 63
Thanks Given: 410
(15-03-2011, 10:11 PM)thowman Wrote: Single door. I haven't seen any twin door Multispaces in the UK, however all the ones I saw in Spain have 2 doors....
I've seen one, on a 2009 plate, one of the last mk2 multispaces, not many about though.
Threads: 41
Thanks Given: 82
6
Mines not worked since I bought my berlingo, it just makes a sort of grinding noise and doesn't do anything.
Threads: 147
Thanks Given: 263
11
Bumping this one for a solution!
Threads: 9
Thanks Received: 28 in 21 posts
Thanks Given: 18
I can't solve it, but I can say that on our Mk 1 Berlingo, the rear wiper failed after 5 or 6 years. I didn't think it was worth fixing, so never bothered. The wiper is still working on our Mk 2 Berlingo, but I rarely use it.
It seems that rear wiper problems are fairly common on old Berlingos.
Threads: 25
Thanks Given: 44
12
Northman.
I can send you electric diagram of yor berlingo, but i need VIN. Sen it to PM
Threads: 9
Thanks Given: 18
I think that it is throwman who needs it, not me. (Our Mk 1 Berlingo is no more.)
