  • 7 Vote(s) - 2.86 Average
Replace radiator Crossmember Front
have to replace the front crossmember which supports the radiator. I'm sure this is the part?
http://www.tarostrade.com/radiator-suppo...-050900500
Does anyone know if this is welded or bolted on?
Hi, be careful this might be for the Mk2. P/Mail me your Vin No. and I'll dig out the correct part No. :thumbsup:
sorry in have a MK2 it a 1.6 hdi 600 2008.
Thanks for your help. but Im all new to this whats the Vin No??
VIN No is your vehicle identification number, have a look through the bottom of the nearside windscreen and you will see it. Or its stamped into the offside inner wing/chassis member in the engine bay. I think its about 17 letters and numbers Hope this helps
  • ron
the Vin no is VF7GB9HWC94381510. Thanks a million
If it's item one you want it's "7106 c7". (bolted)
Or item two "7209 95". (welded)
Confusedalut:
[Image: mczzgo.jpg]
[-] The following 2 users say Thank You to Rustscrat for this post:
  • ron, staggc
Thanks a million. Its item two I need to replace. Would it be ok to cut it out and replace like for like?
Should be, found this procedure.Confusedalut:
.pdf   crossmember replacement.pdf (Size: 89.94 KB / Downloads: 19)
[-] The following 3 users say Thank You to Rustscrat for this post:
  • Husqyman, ron, staggc
Where are you getting this info Great stuff. thanks a million.
No worries, your welcome. Confusedalut:
Users browsing this thread: 3 Guest(s)
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
