  • 8 Vote(s) - 2.88 Average
Electrical. No brake light LHS
No brake light LHS or center light all other bulbs working. Changed all bulbs to make sure and checked all fuse's. Any suggestions
The brake pedal switch . ?
Check for voltage at the switch, ignition on. Its slightly akward to get to but I think you need to remove the fuse box flap/cover under the steering wheel.
id be looking at earth on the centre one...if other lights in the left cluster ar working that should be earthed ok, corrosion in the bulb holder so bulb not earthing...does the red rear light work?.... could be a broken wire to lhs cluster.... cant be the switch if rhs is working.
If RHS light working, could be a break in the loom feeding across to LHS and high level lights????
the lights, indicators all work on both sides just have no brake lights on RHS(when looking from the back) and middle. switched over the actual bulb casing today and bulbs still the same problem. So the bulbs and actual casing are working fine. does the wiring go to the LHS or RHS first and the feed across the other side?
Hi, we need to know year, model & engine to give us a clue which drawings to look at. Confusedcratch:
1.6 hdi 600 2007. thanks lads
Rolleyes Sorry !
duff gen I gave you, didn't read your post right.
Confusedillyme:
Ahh, that makes more sense. Check fuse 21 in the Bsi (under steering wheel) this controls the nearside and centre stop light. Confusedalut:
[-] The following 2 users say Thank You to Rustscrat for this post:
  • ron, staggc
also lads. The brake bulb in question has two elements on it. One for lights (which is working fine) and one for Brake lights which is not work for me. this might help unravel the issue
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
