  • 16 Vote(s) - 2.81 Average
Tuning a 1.6hdi 75bnp berlingo
Hi all, I'm after info on upping the power of my 2007 berlingo 1.6 hdi van. It's the 75 bhp version. It's been remapped and I am impressed with the improvement but I started researching as you do.
I believe the turbo on a 75bhp is the same as a 90bhp?
My plan was to decat it but I thought while doing that shall I fit a bigger turbo.
Is the 110bhp turbo a straight bolt on job?
So my thoughts are bigger turbo,decat, remap?
Clutch?
Or just recon the standard turbo and decat then tweak the map more?
I'm after if possible 120 upwards on bhp and more torque.
Thanks for any input.
The twin scroll turbo on the 110, AFAIK, is not able to be swapped
with the original turbo.
Ok cheers why?
I suspect different layout and dimensions.
If it was a straight swap someone here would
more than likely done it!
Does anyone know it the crank, block and cylinder head are the same.
(09-12-2012, 04:44 PM)OlJeffers Wrote:  I suspect different layout and dimensions.
The Garrett VNT one fits Jeffers.
Not got anything to compare it to the 75/90hp turbo to know how much difference it makes. Still playing with my collection/bits.
Looking into the 115hp remap for the 75 also.
:wave:
the turbo might not swap over but what about swaping the manifold also?
a fmic might also be a benefit
project "black and decked" my bagged mk3 berlingo
(27-01-2014, 09:14 PM)creith34 Wrote:  the turbo might not swap over but what about swaping the manifold also?
The 110 VNT fits the orig manifold ok.
Whats a fmic?
Front mount inter cooler (fmic)
Last Post: ADarkDividedGem
Yesterday 08:06 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
