Threads: 32
Thanks Given: 24
Could be anything.
There is no point trying to diagnose this
1) Without the codes
2) You're having it sorted anyway.
Ask to see the diagnostic which will give you the codes, you can then back check that it has been sorted
Let us know how you get on
Threads: 32
Thanks Given: 18
EML and possible causes? It could be ANYTHING!
Threads: 80
Thanks Received: 372 in 315 posts
Thanks Given: 160
13
I had an C3 do it.
Once it had had its entertainment with me, the RAC guy,and his fault reader (couldnt find any) it was normal service resumed.
• Ian A
Threads: 7
Thanks Received: 8 in 4 posts
Hi, Thankfully my Blingo 2.0 HDI runs just brilliantly but l also have a SEAT Altea which had problems as you've described.When l first got it, a 2007 SEAT Altea 1.9tdi (32k miles), it went into limp mode several times in the first 10 days with much the same symptoms. The seat dealer claimed no fault code was showing and basically didn't care however one of the mechanics told me it was a common fault if the car hadn't been driven above 40mph for a while or driven round town without a chance to warm up properly. He suggested adding Forte diesel treatment to an almost empty tank and leaving it in 3rd gear while booting it down the motorway!! So l did and its not happened since. Search wikipedia and you'll find VW engines are particularly prone to limp mode. I also use Millers additive now each time l fill up. No more limp mode in the last 17 months. Okay so its not a Citroen but l'm sure it applies just the same. Its also worth mentioning limp mode rarely shows a fault code!! Diagnose it the old fashioned way.
The following 1 user says Thank You to bigsacs for this post:1 user says Thank You to bigsacs for this post
• Ian A
Threads: 51
Thanks Given: 23
Just to add to the speculation, I had a 1.9TD Alhambra with similar symptoms. Turned out to be a knackered turbo
Malc
Stupid computer!
Threads: 63
Thanks Given: 410
Not being arsey but I think I would take it back to the Citroen dealer with the fault still active and let them diagnose straight away. If you go back a week later then the fault may have cleared itself only to re appear at a later date, possibly when you are out of warranty.
Another thought, my local main dealer tried to charge me upfront for a diagnostic test while my motor was still covered by a Citroen Select Used Vehicle Warranty and stated that if "No Fault Found" then this cost would be out of my pocket and not chargeable to Citroen Warranty.
Further thoughts, There are "dealers" and there are "stealers" and there are so called factory trained experts who have not got a damn clue.....
Have a look through some of mine and other peoples postings regarding a fault code scanner, after months of sitting on the fence I finally bought one and it works on 2.0HDI (Not all devices will communicate with this engine)
Good luck and let us know the outcome
