  • 9 Vote(s) - 2.44 Average
2004 1.9 berlingo locking delay problem
Hi guys
I have just bought 2004 1.9 berlingo multispace
The problem I have is that once the engine is stopped and the key removed the battery light and the multifunction display stays illuminated also the central locking using the fob does not work.
After 2 minutes though the light & display go off and the central locking works off the fob and the fob keeps working until the engine is restarted.
Does anyone know why this is happening and is there a cure.
I previously had a 2003 2.0 berlingo which had no delay/problem.
Cheers Jim
Worth trying a BSI reset. Search for it on this forum
Mike
Hi Mike
Thanks for the reply.
I have tried a BSI reset but it is still doing the same.
Cheers Jim
Hi JIM
I have exactly the same problem, did you manage to get this issue sorted in the end?
Mike
Hi Berlingochill! Problem is that this post is over a year old and the OP
hasn't been back since! It happens a lot. Start a new thread and the chances are that you'll get some
useful suggestions!
Info display
Last Post: Stevie C
20-06-2025 09:59 PM
Brake problems again!
19-06-2025 08:47 PM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
18-06-2025 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
18-06-2025 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
