  • 6 Vote(s) - 3.33 Average
electrical problem - non start
Hi, i'm new to this forum, recently purchased 03 model van 1.9d, everything perfect until when i went to start it on saturday. ignition lights come on, engine turns over but doesnt start. also noticed, the glow plugs aren't coming on, blower motor & wipers dont work. All fuses ok, removed bsi and visually examined it, no signs of water or other damage. Any help/advice would be apprieciated before i start spending big money on it
Hi, did you get two sets of keys, if you did try the other one.
Is there any white smoke coming from the exhaust? Confusedcratch:
(19-12-2012, 04:38 PM)Rustscrat Wrote:  Hi, did you get two sets of keys, if you did try the other one.
Only one key with the van, no white smoke from exhaust
Hi i had a simular problem a few months back my van just cut out on the way home from work and when i tried to start it i noticed that the glow plug light had gone anyway it went in to citroen and ended up being the bm34 fuse board thats the one near the battery had tried everything before that bsi/ecu/all fuses but it took citroen to find the problem
Could be the immobiliser hasn't unlocked as there is no smoke.
Check the transponder coil around the ignition switch for continuity.
I've had one where the wire had come of the soldered connection. :thumbsup:
Check your fuel cut off switch in the engine bay. red switch left hand side on my MK1 1.9d.
My front springs broke and the shock of it made the car think it was in a accident. when i came to start the car the hazards would come on every time. No fuel so would crank all day but not even a hint of smoke out the back. pushed the switch on the top heard a click and it started first time.
[-] The following 1 user says Thank You to Ricbob123 for this post:
  • Rustscrat
Berlingo undertray
Today 04:46 PM
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
