  • 5 Vote(s) - 3.6 Average
drive shaft oil seals
ive just fitted a new clutch in my 1,9d 54 plate van and have developed a leak from the drive shaft oil seal is this a common fault and is there anything to watch out for when buying/fitting them as i ended up with the wrong cluth 1st time and cant cope with a drive shaft off again and not having the right part
regards janine
Normally it's good practice to renew both driveshaft seals and the input shaft seal when doing a clutch. They get a bit "woody" with age and thus easier to damage. Most factors should have seals to suit, if you go in with the VIN.
Biggest hassle is dropping the gear oil (again!) while renewing the seals. I'm one of the old school "damn the instructions" types who will use the lightest smear of Hylomar or Permatex #3 inside the seal recess.
  • janine
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
