  • 5 Vote(s) - 3.2 Average
where to find fuse chart?
Hi as above, not had this van long so trying to find my way around this thing and sort all the silly little things left from the previous owners. m49 1.9d, 1999.
need to find a fuse chart to see what is powering what.
thank you.
If this helps
F1 10AMP =RADIO
F2 5AMP =ENGINE CONTROL UNIT, INSTRUMENT PANEL
F3 15AMP = ABS
F4 5AMP = LH FRONT SIDELIGHT, RH REAR SIDELIGHT.
F5 NOT USED
F6 10AMP = AIR CON.
F7 20AMP = HORN,DIAGNOSTIC CONNECTOR.
F8 = SHUNT
F9 5AMP = RH FRONT SIDELIGHT,LH REAR SIDELIGHT,NUMBERPLATE LIGHT.
F10 20AMP = ELECTRIC WINDOWS.
F11 20AMP = PASSENGER WINDOWS.
F12 20AMP = REVERSING LIGHT, ENGINE COOLING FAN AND BRAKE LIGHTS.
F13 5AMP = DRIVERS ELECTRIC WINDOWS.
F14 10AMP = CENTRAL LOCKING.
F15 15AMP = CENTRAL LOCKING.
F16 15AMP = FAG LIGHTER.
F17 NOT USED
F18 5AMP = REAR FOG LIGHT.
F19 5AMP = INTERIOR ILLUMINATION.
F20 25AMP = HEATER BLOWER.
F21 5AMP = HEATED REAR WINDOW, AIR CON.
F22 20AMP = REAR WIPER MOTOR
F23 SHUNT
F24 20AMP = FRONT WIPER MOTOR.
F25 5AMP = INTERIOR LIGHTING, CLOCK, AIR CON,ENGINE CONTROL UNIT.
F26 15AMP = DIRECTION INDICATORS, CENTRAL LOCKING.
F27 30AMP = HEATED REAR WINDOW.
F28 15AMP = ELECTRIC WINDOWS, ELECTRIC MIRRORS.
F29 30AMP = AIR CON, HATED SEATS,
F30 10AMP = DIRECTION INDICATORS, INSTRUMENT PANEL, INTERIOR LIGHTS, CENTRAL LOCKING.
Hope this is of some help but don`t take it as gospel.
There is also a small engine fuse box.
F1 20AMP = HEADLIGHT WASHER.
F3 30AMP = ENGINE COOLING FAN
F6 30AMP = ABS.
F9 10AMP = FUEL PUMP.
F10 5AMP = OXYGEN SENSOR.
F12 10AMP = RH MAIN BEAM.
F13 10AMP = LH MAIN BEAM.
F14 10AMP = RH DIPPED BEAM.
F15 10AMP = LH DIPPED BEAM.
There seems to be a lot of dupilcation
[-] The following 3 users say Thank You to Tomcat3 for this post:
  • amtech, ron, whitebus
(23-12-2012, 10:17 PM)Tomcat3 Wrote:  If this helps
F1 10AMP =RADIO
F3 15AMP = ABS
F5 NOT USED
F6 10AMP = AIR CON.
F8 = SHUNT
F17 NOT USED
F23 SHUNT
F6 30AMP = ABS.
haynes manual also lists in the engine fusebox maxi fuses a to h, but only says "should only be changed by main dealer". it dont say what these fuses do or their rating, you have to delve into he wiring diagrams to get any further
[-] The following 2 users say Thank You to ricc for this post:
  • amtech, whitebus
thank you. i must get myself a manual!
The maxi fuses include cooling fans and upstream supply to the minor fuseboxes. The only unfused connections are to alternator and starter motor. Makes alt diode failures easy to test; pull the maxi fuses and if you still have a current leak it's a shorted diode!
Haynes are traditionally useless in this capacity, the PSA system of wiring diagrams are possibly among the best worldwide; simple and clear.
[-] The following 2 users say Thank You to addo for this post:
  • amtech, Ol'Jeffers
hi were is the fuse for the window washers
Air filter box removal
Today 06:23 AM
Yesterday 10:10 PM
» Replies: 21
Berlingo undertray
Yesterday 09:59 PM
» Replies: 19
Yesterday 04:25 PM
Yesterday 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
