  • 4 Vote(s) - 3.75 Average
Ipod conection
Has anyone fitted a ipod connector to the existing radio? I have tried a FM jobby which was very poor and I dont really want to change the head set.:brickwall: I have a 09 Berlingo.
regards
John Confusedcratch:
There's not really any other option for a stock CD head unit, as it has no 'input' for an external source. Your only option is to switch to an aftermarket unit with Aux input or iPod connectivity.
You can fit something called an Xcarlink to the CD changer connection on the back of your radio, it then needs configuring using Lexia.
If it is a new shape Berlingo has it not got a pair of RCA phono connectors in the glove box?
I connect an mp3 player up using that. I have a lead with rca plugs at one end and a 3.5mm jack at the other end.
Peter
(27-12-2012, 01:36 PM)Romahomepete Wrote:  You can fit something called an Xcarlink to the CD changer connection on the back of your radio, it then needs configuring using Lexia.
Thanks Peter
What do these RCA connectors look like?
John
Peter
RCA connectors are red/white like what are on hifi seperates believe they are also called phono plugs , see picture below.
[Image: 9h02mb.jpg]
Hi there, I have seen the connector cable at Poundland, sorry I can't remember the price.
[-] The following 1 user says Thank You to Tonyash for this post:
  • ffrenchie
(27-12-2012, 04:12 PM)Tonyash Wrote:  Hi there, I have seen the connector cable at Poundland, sorry I can't remember the price.
Last time I asked they were a pound Big Grin
Well thanks guys so far. My Berlingo does not have the plugs mentioned in the glove box. However, there is a green plug/socket on the right hand side of the glove box! any ideas what that could be??:brickwall:Confusedalut:
(30-12-2012, 05:31 AM)silverfox Wrote:  Well thanks guys so far. My Berlingo does not have the plugs mentioned in the glove box. However, there is a green plug/socket on the right hand side of the glove box! any ideas what that could be??:brickwall:Confusedalut:
If it's about 2 inches x 1inch, it is the connector for the computer diagnostic.
If you mean this socket then yeah its for the diagnostics. The aux socket is top left but it sounds like yours doesnt have this, what model have you got.
[Image: 2m4yb2s.jpg]
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
