Threads: 63
Thanks Given: 410
Nice one,
Does anybody bother to strip down and overhaul their own gearboxes these days???.
In the world of heavy goods vehicles they still repair gearboxes to some extent but I think that in most other car and light commercial garages it is unit replacement. Ask the mechanics and they probably have not stripped or overhauled a gearbox in ages.
Threads: 63
Thanks Given: 410
Here in England we don't seem to bother so much nowadays. In my youth we used to pull apart and repair gearboxes and engines to our heart's delight. Ford Cortina Mk11's, Escort Mk1 and 2's, used to do them in my sleep.
Big thank you for the link to all of the manuals, excellent and thanks once again
Threads: 63
Thanks Given: 410
Hello pk7478,
You have not heard or seen Ford Cortinas or Ford Escorts, what a shame you have missed out in this life!!!!. Only joking my friend, please appreciate this very British humour.
In their day, 1970's to 1980's era they were a young man's passion and pride and joy. Traditionally they were unreliable, mechanically simple to fix but always needing something fixing and yes, the bodywork seemed to corrode into non-existence before your very eyes.
Probably the modern day equivalents would be the Citroen Saxo, Pugeot 206 or 306 and the Vauxhall Astras and Novas.
How times have progressed!!!!
Threads: 5
Thanks Received: 23 in 3 posts
Thanks Given: 3
02-12-2011, 11:01 AM
(This post was last modified: 04-12-2011, 11:18 AM by Tenere.)
Hi folks
The download link for the gearbox data is not delivering. Anyone know of another link or could possibly send it to me? (GOT THE LINK NOW - THANKS....wrong box unfortunately!)
I would like to check my gear oil level and possibly change it too. I'm getting a small drip of oil on my drive and it appears to be coming from the near side of the engine. Is this common? I can't seem to tell what the oil is as it doesn't whiff like gear oil used to, but with modern oils perhaps it wouldn't. I suspect it is just engine oil but want to check the gearbox as a precaution. I understand the gear oil is not generally changed in services - is that right or is there a service interval that includes it?
Also are there any known common oil leak points?
thanks for reading....any help most appreciated.
'07 600x 1.6HDI 75 Berlingo (M59) short van
RPO: 11251
Engine: DV6B Gearbox: BVM5 BE4-5L
tudy: MK2 1.6HDi 75 short van '600' M59
'07, 80k
DV6B Engine
BE4-5L manual gearbox
Threads: 51
Thanks Received: 35 in 32 posts
Thanks Given: 3
It's not done during a service.
If your right hand drive,
Turn your wheel all the way right.
There is a drain point at the Bottom of the gearbox,
Looking in the back part of the front wheel arch and follow the gearbox bolts up the side there's a large bolt at about the 3 o clock position. Fill untill it comes out when the car if level.
Easy enough job.
The drive bearings seem to be bothersome since both of mine are suspect
The following 1 user says Thank You to corkgsxr for this post:1 user says Thank You to corkgsxr for this post
• Tenere
