  • 9 Vote(s) - 2.33 Average
Starter Motor
Having some intermittent problems with my starter motor. as soon as its dry and i get a chance ill have a look at all the connectors but for now can anyone tell me if it was the solenoid would i still hear the motor spinning?
the car bumb starts just fine btw.
my guess is its the brushes as when i turn the key i get nothing, no spinning sound from the motor and no cranking from the engine.
if it is the motor its looks like ill have to get a new one, right? cant find anywhere that does replacement brushes, anyone know better??
Hi RicBob,
With the headlights on try starting it. If there is no dimming of the lights then no power is getting to the starter motor. Make sure all connections are clean, including battery to body earth, and try again. It is possible to bench test the motor, if you can remove it, and this will cut out the vehicles wiring.
HTH,
Griff
Landmark
Ex 1.4 Berlingo Multispace
[-] The following 1 user says Thank You to Landmark for this post:
  • ron
(02-01-2013, 05:38 PM)Landmark Wrote:  Hi RicBob,
HTH,
Griff
Thanks griff
With it been an intermittent problem i never know when its going to happen, but will try this if its dark the next time im having problems.
So the theory is if the lights dim then power is getting to the motor but if the engine doesnt crank then it will be the solenoid (or something related to it, wiring, fuse etc) correct?
Battery could be breaking down intermittently also
  • ron
Try tapping the solenoid and motor body with something, my old motor used to do it and once it had a little tap with the end of a piece of bar it worked for months before it did it again. I think it was scared it was going to get hit again.
  • ron
Exactly what mine has done twice, intermittently you turn the key and it just clicks and has to be bump started.
Both times the starter needed replacing.
HTH,
Griff
Thanks griff
Yes, That's how I understand it too.
Griff
Landmark
Actually, if the solenoid is duff it may not even slightly pull in. The dimming could well be due to ageing battery leads or a dying cell in the battery.
For many starters and alternator parts, I've hadd decent results from Wood Auto - even with postage they are less hassle than Oz suppliers.
Users browsing this thread: 2 Guest(s)
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
