  • 8 Vote(s) - 3.25 Average
Lowering Berlingo torsion
Hi guys. Ive been struggling to remove rear torsion. I got the front one moving but cannot get rear to budge. Used a slide hammer etc but no joy.
Anyone local to kettering area that does them or anyone have any ideas
Both sides on mine were a complete B*sta*d.
In the end the only method that worked for me was to carefully heat the female side splined area, trying not to damage any plastics or rubber seals, with an oxy/acetylene (or plumbers torch) and let it cool.
Soak the splines again in WD40, find a 4Lb or heavyer lump hammer, a drift that's a slightly smaller size than the torsion bar splines and try beat the torsion bar through from either end with brute force. You'll know when you've broken the siezure as the hammer blow noises become duller.
Then work the bar back and forth, every so often spraying the splines to clean off rust cake, until eventually it'll push through.
Once you've freed them off, wire wheeled them clean, copper greased them, they go in and out again easy!
Not sure how far from Kettering Dorking is but a fella called Kris is highly recommended on the 306 forums I use.
http://www.krisb.co.uk/
Must admit I didnt even attempt mine, Let a local french car specialist do it instead.
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free Smile
[-] The following 1 user says Thank You to PeteA for this post:
  • chronyx
Ended up dropping the entire rear beam assembly out on mine, and taking big swings on a 15lb sledge hammer before mine came out, and that was only on the subframe end.
Torsion bars are hateful things, I'm never touching them again.
Dorking to Kettering is about 110 miles.
I've messaged KrisB as he is close enough for me to benefit by using him.
He also has some pretty good testimonials....I'm impressed.
Same here, good to know.
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
