  • 5 Vote(s) - 4.4 Average
Door Handle Precaution
Back when I had my 2010 van, we had some bad weather that included a rainstorm, then an overnight freeze .
The plastic seal that closes off the holes on the doorpanel froze to the paint and then broke away from the handle when it was pulled.
The seal then dangled around its pin and left the holes exposed to the weather.
This time I greased the paint behind the seal.
Fingers crossed -hope this might help someone elseConfusedalut:
[Image: mrto48.jpg]
  • 3rensho
Good call, will be doing mine tomorrow!
That's a great tip. Something I'd never have thought of. Thank you.
Vaseline.....the answer to many different problems.
  • ron
"Teas nearly ready -where are you going?"
Just popping out to ,err,put vaseline on the door handles dear"
You'll have the house all to yourself for at least the weekend:thumbsup:
  • ron
An update -it works
Came out of work this morning ,paddled through the frozen slush, and without thinking yonked open the door and just saw/heard the seal start to break away but the half frozen grease stopped it fully separating so all is well.
(24-03-2013, 09:14 AM)evdama Wrote:  An update -it works
Don't be sparing with the vaseline.:whistle::whistle:
or get grit in it....
(25-03-2013, 07:45 AM)evdama Wrote:  Don't be sparing with the vaseline.:whistle::whistle:
[/quote]
Oo'er.:eek::eek:
Last Post: magoo1
Yesterday 06:31 PM
» Replies: 74
Last Post: Dyane6
Yesterday 05:19 PM
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
