24-02-2013, 05:54 PM (This post was last modified: 24-02-2013, 06:01 PM by ffrenchie.)
My niece liked the Citroen so much she wanted one but she bought a Partner instead. It's a Quicksilver and I'm having the roof bars off it when I get a pentagon key to fit them (ordered one already).
The following 1 user says Thank You to ffrenchie for this post:1 user says Thank You to ffrenchie for this post • addo
Careful trying to do undo the bolts....somewhere here I read that they can shear or the heads round off
and then refuse to budge. I think I'd buy a can of dismantling fluid beforehand!
This is probably one of the best things that Halfords sell!! http://www.halfords.com/webapp/wcs/store...-_-TopLink
You can also still get Plus Gas which is way better than WD40.
I don't think you can compare Plus-Gas with WD40.P-G is a freeing agent only whereas WD40 is a multipurpose gunge. If I had to choose only 1,it would be WD40.
(22-10-2013, 07:14 PM)ron Wrote: I don't think you can compare Plus-Gas with WD40.P-G is a freeing agent only whereas WD40 is a multipurpose gunge. If I had to choose only 1,it would be WD40.
Agreed Ron, but I've had cases where WD40 failed to 'unseize' a bolt after a number of hours soaking and Plus Gas did the job very quickly.
I wouldn't buy one or the other, I have both.
Threads: 67
Thanks Given: 1,045
