Threads: 12
Thanks Received: 4 in 2 posts
Thanks Given: 3
Hi which number fuse operates the washers please on berlingo van 2008 new shape please? wipers work fine just washers dont thanks.
Threads: 43
Thanks Received: 412 in 369 posts
Thanks Given: 137
33
seemily they work through the BSI. As far as I know there are no separate fuses for the washers. Could be the pump motor or switch.
Rustacrat is the man who knows ,
Threads: 50
Thanks Given: 743
My money would be on the pump motor. Not expensive....under £20 IIRC.
Threads: 32
Thanks Given: 18
Have you checked the tank is full???????
Threads: 81
Thanks Given: 165
20
(06-01-2013, 11:21 AM)raptornexus Wrote: Hi which number fuse operates the washers please on berlingo van 2008 new shape please? wipers work fine just washers dont thanks.
I've rtfm -mine is Enterprise spec but the front and rear washers are 10 amp in the engine compartment at Fuse 3,which is roughly in the centre of the board.
Threads: 12
Thanks Given: 3
Ok thanks,there are fuses under the glovebox on passenger side but i cant see how you get to them?
Threads: 81
Thanks Given: 165
20
No - there is another fuseboard in the engine compartment
Fuse 3 is the one you're looking for-its a mini 10A ,near enough in the middle of the board and possibly next to a full size fuse.
