Threads: 39
Thanks Given: 1
4
I do both ours every 6 months, on the car it works out about 6000 miles and our Romahome about 4000. It fits with the MOTs because one is Feb and the other is September. I do it as part of the pre MOT service and checkup and I do both vehicles together.
Peter
Threads: 15
Thanks Given: 46
5
Interval is 12,000miles. I think nowadays you can have it serviced at mileage rather than time, ie not annually if you yearly mileage is below 12k but I do have mine serviced every year which is normally between 9-10k miles. It is important to use correct oil. I always use Citroen dealer workshop which at least(one hopes)ensures correct oil is used & correct change procedure also which is important to get sludge out, apparently.
Threads: 52
Thanks Given: 87
5
I do mine every 10K km (filter too). So far I've used only Total Quartz Ineo ECS 5w-30.
Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
07-01-2013, 02:55 PM
(This post was last modified: 07-01-2013, 02:56 PM by taxi.)
Get mine done c/w filter every 10k using low ash oil.
Former 2011 Mk3 XTR owner
alut:
