  • 5 Vote(s) - 3.4 Average
wont start
hi
my berlingo 1,9 2001m have some weird problems, temp gauge and fuel gauge aint working, senders are ok, all warninglights are flashing when i turn on ignition, but starter wont run, its all dead. any idea where to start looking ? Well someone in here must have a clue, its a citroen Smile
rabalder
Have you checked to see if there is power going to the starter motor when the key is turned, i not a mechanic or anything but thats what i would check first. Does yours have a BSI if so it may be worth while doing a BSI reset just do a search on forum and it will bring up the procedure
(10-01-2013, 09:05 PM)BerlingoHDI Wrote:  Have you checked to see if there is power going to the starter motor when the key is turned, i not a mechanic or anything but thats what i would check first. Does yours have a BSI if so it may be worth while doing a BSI reset just do a search on forum and it will bring up the procedure
thx for answer, funny part is that the sterter problem began while searhing for the other problems, yes it has bsi and i have done that reset procedure, battery is fully charged, checked all grounds connection that i have found, but nothing helps, will do more tomorrow, there is power on every thing , headlights wipers flashing in dashboard, but starter, not a chance, feels like a connection that is burned off, all dead, will check wires to starter tomorrow, but bsi reset dont work, been looking for connection that could have corr due to waterleaks etc, fixed the one i found, but could be some more.
If you have two keys, try the other one....could be an immobiliser fault.
(11-01-2013, 12:07 AM)OlJeffers Wrote:  If you have two keys, try the other one....could be an immobiliser fault.
Hey
Yep key problem crossed my mind, but I only have one key, but since it work switching something alive why not the starter and why aint it possible to reset bsi....
rab
The key, if it is the same as later vehicles, 'talks' to the immobiliser when inserted so
either the key sender may be damaged or possibly the receiver coil near the ignition switch.
But I don't know if your 1.9D has the same type of immobiliser as, say, my 1.6HDi.
Have you tried to bump start it? i have a problem with my starter at the mo, sometimes it just wont crank and i have to bump it. i think its the bushes on the motor and i'll be getting a new one when ive got the cash.
i dont have any problems with my instruments tho to be fair. If it bumps investigate the starter as the instrument problems may be unrelated.
(11-01-2013, 03:20 PM)Ricbob123 Wrote:  Have you tried to bump start it? i have a problem with my starter at the mo, sometimes it just wont crank and i have to bump it. i think its the bushes on the motor and i'll be getting a new one when ive got the cash.
yes i might try that,thx, fingers crossed
Oil consumption at 200K miles
Yesterday 02:32 PM
Forum activity
Yesterday 06:32 AM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
