  • 9 Vote(s) - 3 Average
[Engine] Fault Code P1351
Fyi,
Fault Code P1351 on my 04 2.0Hdi was generated by causing a block in the Vacuum pipe that is connected to the EGR Valve.
During this fault the car went in Limp-home mode and needed to be reset via the Code reader.
[-] The following 1 user says Thank You to Stinky Pete for this post:
  • Rustscrat
Hi stinky Pete, i have the same code coming up on my car, i am having difficulty starting when cold so i presume it is the glow plugs as the code is related to them.
i also seem to be lacking a bit of power but there is no engine management light on so i am unsure whether it is in limp mode or not has it does rev up to around 4k .
where shouts is this pipe you mentioned and is it a simple job to do as i believe it is worth trying for nowt.
The EGR solenoid can be seen here :-
- it is the one with the blue plug attached. You can just make out the two pipes above the plug.
One leads to the EGR valve which looks like this and connects where circled:-
it is mounted onto the exhaust manifold.
I would normally expect a fault with the EGR system to start with P04
Pics are arse about face.
(28-02-2013, 12:59 PM)Coco Wrote:  The EGR solenoid can be seen here :-
....together with the mild pickle. I remember my father kept Colman's powder to fix leaks in the Lanchester's radiator - what does the pickle do? Does it have to be lime?:Rolleyes
CandR Wrote:....together with the mild pickle. I remember my father kept Colman's powder to fix leaks in the Lanchester's radiator - what does the pickle do?
I think it helps keep the exhaust unblocked? Wink
Confusedtudy: Warning (see section 27.b) Do not stand behind vehicle while revving engine.Rolleyes
(Note: Since vehicle number *********, earlier specified addition of Indonesian sambal paste deprecated)
Now you're all just trying to curry favour with me.
(01-03-2013, 04:52 PM)Coco Wrote:  Now you're all just trying to curry favour with me.
Of course we are!!Big Grin Big Grin !
It's special for us to see what a real mechanic has on his or her workbench - there might be really special tidbits for us to takeaway from the experience! SmileConfusedalut:
Nah, we all just hope to see a glimpse of the Wurth calendar on the wall.
There's little of any worth on my walls
Last Post: BigVtwin996
Yesterday 08:25 PM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
