  • 12 Vote(s) - 3.17 Average
wheel spacers????
any one fitted 5 mm wheel spacers to their berlingo? considering doing this when I put my alloys back on next week, just to space it out a bit. Any thoughts, on internet there seems to be confusion over whether they are safe or not?
Any thoughts.......?
Pete
i dont have them but i have herd they can reck wheel bearings but thats over 20mm i have herd so 5mm will be ok =)
get a life get a van !
thats what I also read, cheers
They alter the angle at which the pressure from the wheel (load) is transmitted to the bearing. So yes, they can cause wheel bearings to wear out faster. Having said that, 5mm is negligible and I don't think it will make any noticeable difference.
Do you need them for clearance or is it cosmetic?
just cosmetic, so your answer wont make any noticable differance did that relate to looks or wear?
cheers
Pete
Do you have to change the wheel bolts with 5mm spacers?
I am told on line by various forums no, but as long as 1 and half time bolt dia lock up, so again very vague answers, other reports say as above it may / will wear bearings out quicker , [ under warranty for 2 more years so can bullshit that one] Unless they come under fair wear and tear policy.......bastards have you every way....ha ha .....
In the end may just think what the hell is it worth it?
not sure yet.....
Pete.
Warranties are such a mine field. Look at any small print and they will tell you that modifications will invalidate it. I guess that it depends whether or not you think that you can get round a potential issue by changing parts back. And this is before you get onto insurance and declaring mods....
think I will just end it all instead......so much red tape to enjoying oneself today....
Enjoy yourself ?????
Whatever gave you the idea that you were allowed to do that
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
