Threads: 80
Thanks Given: 25
Does anyone know how to and where do leads go to use leads to start another car?
On mk 3 there appears to be no where to attach leads to.....
I tried opening red cover over battery terminals and broke the bloody thing [ other mk 3 owners beware]. fortunately under first service they replaced broken cover....
pete.
Threads: 4
Thanks Received: 1 in 1 posts
Thanks Given: 3
the possitive is at the front and the negative is beside if not earth it on the body but you have to have the engine running if its a mk3 berlingo because its a closed circit or something like that i found out that when i had problems with my mk2 and tryed strarting it off my dads mk 3 van without the engine running and nwt happend
get a life get a van !
Threads: 80
Thanks Given: 25
sorry excuse my ignorance...front o what ..the red cover? I cant see any bear wires / terminal connections.... and I didnt want to ask citroen as they were replacing red cover free of charge....otherwise they might have charged me..
Pete
Threads: 52
Thanks Given: 87
5
Hi,
on my mk3 you never need to remove the red cover. (I did once just to see what was under there - looks like voltage regulator) The pos. lead is to the left of the red cover when you're standing in front of the car looking aft. It is bright and shiny. For the neg lead I just use any exposed metal that is clearly connected to the chasis.
Tom
Threads: 16
Thanks Given: 46
5
The positive battery terminal is under black cover on left of plastic battery housing as it faces you. The negative jump lead is connected to the round metal bit screwed to the inner wing on right as you face car.
Threads: 147
Thanks Given: 263
11
Im not doubting you pch, but can it be that hard? Maybe a piccie for us non mk3 owners would be good to see whats going on, because i am confused!
Threads: 80
Thanks Given: 25
ok guys so your saying I have to connect my red to red as shown above? my earth / black to any bit on car body, [ I dont have a red little pad bit like the above, just a bit of flat metal with + stamped on it]. BUT i must disconnect one of the battery leads or I risk burning sommat out.....
and Andre , you dont have to doubt me, I am just thick ,... mechanically , hate the dirty smeely stuff under the bonnet. Gets all ove ryour hands.....and no I `m not queer........Just had a company car from 19 for 30+ years so never had to touch em.
Now I`m paying I have to get into em a bit more...
Pete
