Threads: 16
Thanks Given: 46
5
14-01-2013, 05:47 PM
(This post was last modified: 14-01-2013, 05:49 PM by Opensauce.)
The obvious place would be your nearest Citroen dealer parts dept. Peugeot dealer should also stock them if there is one nearer to you.
Threads: 82
Thanks Received: 397 in 340 posts
Thanks Given: 166
21
14-01-2013, 05:57 PM
(This post was last modified: 14-01-2013, 08:58 PM by evdama.)
Surely the bulb comes out? -bayonet wedge or edison.
More likely a 'BA7'you can get these off t'internet ,from proper car shops,or classic car/bike suppliers.
Thanks Given: 188
23
14-01-2013, 06:16 PM
(This post was last modified: 14-01-2013, 06:19 PM by Tomcat3.)
You can either get them in the holder ( the brown bit) or by them loose. I think its called a capless 286 bulb. just pull the bulb out of the holder they are a push fit you wont break it. I can believe halfords aint got a clue but local car shop shocking, go find a new one my local has boxes of them in every size.
Are we there yet?????
Threads: 67
Thanks Given: 1,045
You can also buy them very cheap from Farnells etc.
Note the LED type don't always fit in the factory holder - I've had to sand a few down . My low fuel one is an LED because it's lit so frequently a normal bulb doesn't last (I'm famous for running the tank to fumes).
Threads: 3
Thanks Received: 2 in 2 posts
Thanks Given: 1
hi they are 5 mm wedge bulbs as fitted to a lot of fruit machines i got some led ones off the bay but they haven't lasted
if you get stuck pm me i have spare 5 mm wedge
Hello. I have a blown bulb in multifunction screen. I've seen how to remove the cover etc to get at the bulb but mine is a different shape and I don't want to shove something in the wrong place trying to remove it. My Berlingo is 2011. Can anyone help please?
Ruth 2
Threads: 123
Thanks Given: 250
34
22-08-2021, 07:45 AM
(This post was last modified: 22-08-2021, 07:46 AM by cancunia.)
I've not done this on a B9 so can't offer any direct advice but on the M59 it's quite straightforward. The W5W bulbs are easy enough to find on eBay etc but you need to be fairly careful about the wattage.
Can you send some pictures? Also a forum search on MFD may help with some clues.
