  • 2 Vote(s) - 2 Average
[Engine] Noisy Engine
Can anyone help? Bought an 01, 1.9 Berlingo a couple of weeks ago and I have noticed something strange happening. If I let the revs get below 2000 rpm's, every so often the engine gets really noisy for 5 to 10 seconds, there is no increase in rpm's and it will not accelarate. as soon as the engine noise returns to normal, acceleration is fine. As long as I keep the rpm's above 2000, this doesn't happen. I have been told before I bought the vehicle, the head was removed for some work to be done.
Any ideas anyone?
Is it drawing air into the fuel system? . Does it do it when pulling up a hill or in neutral?. I would check the fuel filter for dirt and fuel lines for leaks , cracks etc. Removing the head means disturbing the fuel lines and filter assy.
:thumbsup:
(16-01-2013, 10:39 PM)brodfather11 Wrote:  Is it drawing air into the fuel system? . Does it do it when pulling up a hill or in neutral?. I would check the fuel filter for dirt and fuel lines for leaks , cracks etc. Removing the head means disturbing the fuel lines and filter assy.
:thumbsup:
Thanks for replying. The problem occurs whatever the terrain, but only when under 2000 rpm. It doesn't do it when ticking over though.
Last Post: mikeh79
Yesterday 07:00 PM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
Last Post: Buki
31-10-2025 07:26 PM
