Threads: 16
Thanks Received: 4 in 2 posts
Thanks Given: 11
Hi guys, my 2.0 hdi takes a while in the morning to start. ive charged the battery and that seems ok.
i assume its the glow plugs. my local mechanic said their awful to replace and are normally seized in. is he correct or just after more money? its a november 2004.
could their be any other causes for poor starting?
cheers Chris.
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 139
33
Hi
Good glow plugs are essential for good starting . They are usually quite tight to remove if they have not been changed but with a little patience they will come out.
Changing them if that is the problem, is worth it. Get them changed or at least tested
:thumbsup:
Threads: 28
Thanks Received: 68 in 50 posts
Thanks Given: 29
Hi there i have never had to change them on my 2.0 hdi yet but i think they are due as past week it has struggled to start a little. I have changed them on loads of other diesels and not had a problem, i normally get the engine warm before doing the job as they seem easier to come out. i would have thought about £60 to supply and fit a set of glow plugs.
there could be other possibilities for poor starting but does it only take a while to start when it is realy cold or can it be at any temperature, even on a summers day does it take a while.
Threads: 32
Thanks Given: 24
Did mine a couple of years ago - no bother.
Give them a soak the night before with WD40 etc just to help things along and just take your time
Threads: 67
Thanks Given: 237
50
If you have a multimeter or access to one then the best thing to do before going to a garage is to test for voltage at the glow plugs - no voltage no cold start system operating - and then check the continuity across each glow plug. From here you know whether to spend money or not.
As said above ^^^ remove glow plugs from a hot engine due to the differential expansion rates of alloy versus steel, makes for an easier job.
Serieal Berlingo owner
• ron
Threads: 29
Thanks Given: 67
20
14-02-2013, 10:24 AM
(This post was last modified: 14-02-2013, 10:27 AM by ffrenchie.)
My battery died early doors this winter so I fitted a new one but I found it still churned over for a while before starting if I turned the key straight to the start position. If I wait for the coil light to go out when it is really cold it fires up after two or three turns of the engine. I was told to just keep churning and ignore the light when I bought the car but it seems counter productive when my engine starts easier the old fashioned way.
