Threads: 32
Thanks Given: 24
You will need the stalk with the switch on it, the stalk is integral to the Com2000.
You will probably also need to get them activated in the BSI with Lexia
Threads: 67
Thanks Given: 238
50
Personally I'd wire the lights up in the conventional manner with a separate loom running a fuse and relay and not get involved with Comms and Lexia. Expense and future hassle. Put the switch in the dash in a spare " hole ".
Serieal Berlingo owner
• ron
