  • 6 Vote(s) - 3.33 Average
Mk2 1.6Hdi normal coolant temperature?
Folks, our Berlingo normally runs at about 80C but seems to take quite a while to get there especially in this cold weather.
This could be normal so I'm just looking for opinions. Lazy thermostat perhaps? I've contemplated applying the old short-term winter fix of blanking off a bit of the radiator but has anyone else tried this? It ain't the weather for working under the bonnet ouside!
That sounds about right my van takes about 4 to 5 miles to fully warm up then sits mid way on the gauge around 80c all day.
[-] The following 2 users say Thank You to Tomcat3 for this post:
  • pidgeonpost, ron
Fair enough - thanks. I'll stop wondering then. :thumbsup:
Just for extra reassurance,mine does the same & has from new.I would be careful blanking the rad,but if you want to try,start with a small blank.
That way you won't get any sudden overheating.
  • pidgeonpost
both of my pugs (306 and 406) ran/run just under 90, and it also took/takes about same time to warm up.
[-] The following 1 user says Thank You to christine for this post:
  • pidgeonpost
It must also be remembered that the temperature gauges
are not reputed to be hugely accurate! So you may see differences
in read out on different vehicles despite the fact that the coolant temperatures
are satisfactory.
  • pidgeonpost
my 2004 2.0hdi is the same was just about to change the thermostat. maybey i wont bother then.
[-] The following 1 user says Thank You to landcrab for this post:
  • pidgeonpost
Mine is typical turbo diesel - next to no spare heat for the heater!
Typical temperature is 80c and will hold this all day long no matter how hot it is outside or how slow the traffic, but it can take ages to get there. Not unusual for it not to reach temp after 20-30 mins this time of year
  • pidgeonpost
Thanks to all who replied! I can now relax knowing we're all shivering together waiting for the warm-up!
I'll steer clear of blanking part of the rad.
Is there no aux heater option? I know Xantias had this (diesel Eberspacher), also pretty sure the C5 could be optioned with an electric additional water heater.
Last Post: TGD
Today 09:50 PM
Today 12:29 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
