Thanks Received: 1 in 1 posts
Thanks Given: 1
Hi there. I'm a new owner of 1.6 hdi as of today it's a 2006 with 75000 on the clock and a stamped book up to 67000 . Now I have never owned a Citroen of any sort before never mind a berlingo. Must say there a nice small car to drive did around trip of 76 miles in it and it's lite on the fuel! Just found this forum with a google search looks like I have some reading to do!
The following 1 user says Thank You to Tom H for this post:1 user says Thank You to Tom H for this post
• addo
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
20
Hello Tom and welcome
Good choice of car however,from the mileages you quote just about everyone here will tell you to get the oil changed pronto.
Do a search on "Turbo" -theres some good advice to be had
• ron
Threads: 19
Thanks Received: 30 in 19 posts
Thanks Given: 38
Hello and welcome Tom. Thats excellent advice from Evdama. Total Quartz INEO 5W/30 ECS oil and a new filter of course. The engine temp at drain down is important too (90'). A check on the oil feed line filter to the turbo (if it's still in place, some people remove them).
All this info is available on the forum. Ol'Jeffers did a good post on this subject as have other members.
Best of luck
Thanks Given: 1
Thanks for the welcome. Yes I have the oil to do ASAP. More than likely it will be next week end. Just have to find the right oil first. I know the Total Quartz INEO 5W/30 ECS would be the right one to use but I have never seen it in any of the local shops. May have to go with the Halfords 5-30w.
Threads: 81
Thanks Given: 165
20
(20-01-2013, 09:21 AM)Tom H Wrote: Thanks for the welcome. Yes I have the oil to do ASAP. More than likely it will be next week end. Just have to find the right oil first. I know the Total Quartz INEO 5W/30 ECS would be the right one to use but I have never seen it in any of the local shops. May have to go with the Halfords 5-30w.
You would find this a a Citroen dealer -
Thanks Given: 1
Will go there then. Thanks for the pointer evdama.
Thanks Given: 1
I was in Halfords yesterday looking at there oil range and seen the 5/30. Just did not have enough cash on me. I was a quid short!
