  • 8 Vote(s) - 3.63 Average
Washer pump motor fuse
The washer pump motor fuse is fuse no 3 under the bonnet. It's 10a mini blade fuse not the standard size.
It's not marked in the fuse compartment or the lide - STUPID.:brickwall:
It is however, in the manual. Spare fuse now in the glove compartment.
[-] The following 2 users say Thank You to RocketVANman for this post:
  • 3rensho, whitebus
Good to know. Thanks
[-] The following 1 user says Thank You to 3rensho for this post:
  • whitebus
Yeah....this is a bloody annoying fault!!! I thought mine had gone again this week but it must have just been frozen! French!!!
[-] The following 1 user says Thank You to robertoc for this post:
  • whitebus
Yep, happens when jets are frozen and repeatedly attempting to activate washer, mentioned on other post about missing spare fuses .
But,some Fiat washer nozzles have a habit of popping out when frozen, which can mean buying new washer unit which is even worse than a fuse blowing. :brickwall:
[-] The following 1 user says Thank You to taxi for this post:
  • whitebus
Super strong screenwash mix wont freeze in the tubes,
Clear the snow off the wipers and de-icer the blades off the glass while the motor is warming up.
Dont run the wipers on an icy screen-it wears them out quickly
  • whitebus
MOT Emissions repeated fail
Yesterday 05:05 PM
Rear door filling with water
Last Post: Marsaday
Yesterday 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
