Threads: 15
Thanks Received: 1 in 1 posts
Thanks Given: 9
Hey all,
I managed to get the BE3 gearbox out and change the release bearing :thumbsup:
Now I'm having trouble with the clutch release fork. It has a threaded bolt going into it but no hex or socket head. I can get a nut onto it but do I keep turning or shall I pull on the nut?
My goal is to replace the shaft sleeve that sits behind the clutch fork and release bearing.
Thanks all.
Threads: 67
Thanks Given: 1,045
I'm fairly sure you drive the threaded end back into the shaft, new pins are available ex-dealer plus Fleabay vendors like Neat Car Parts.
Threads: 67
Thanks Given: 237
50
Put a nut onto the thread and have it flush with the end. Now strike the nut squarely and firmly with a 2Lb hammer and it should move inwards - tapered pin. The last one I did was on a C15 and it was a 7mm nut which was the same as the strut top nuts ( non standard thread ). The Berlingo one is likely to be the same.
Hope this helps.
Serieal Berlingo owner
Threads: 15
Thanks Given: 9
Sorry guys should have emphasized I was trying to get the pin out.
Threads: 15
Thanks Given: 9
So I bang the threaded end into the shaft and through with a punch?
Threads: 67
Thanks Given: 1,045
Yes, that's the approach. If you have a bit of brass rod it will help not damage the threads, otherwise you can try Geoff's nut method.
To draw the pin up tight on refitting, you need a nut/washer on the threads.
Threads: 17
Thanks Received: 15 in 13 posts
Thanks Given: 18
Just wondered how you got on with the pin issue?
Have had same problem myself, beat old one out and beat new one in, bent both as couldn't get straight drive onto new pin, had to buy new fork and arm to get pin.
anyway now its coming off again as bearing gone in gearbox,so replacement gearbox and need to change over new input shaft sleeve.
anyone know where to get just the pin?
'If You're Not Living On The Edge, You're Taking Up Too Much Room.'
Founder Member: The Bad Parent Club!
Threads: 15
Thanks Given: 9
I left my one in. Stupid design. They seem to seize and if you bang them they can destroy the fork-arm's plastic bushes.
Good luck mate.
