  • 6 Vote(s) - 3.33 Average
Van Variants
Evening All,
does anybody know what the D70 means on the variants listed by motor factors.
trying to identify my van it is a 2000 1868cc diesel van with i believe DW8 engine from the vin number.
I think i may have fitted the wrong clutch Valeo 821426, which is why it don't work(no drive) according to an ebay supplier this fits a 2000 1868cc but it is a MPV.
w
What do ya think?
'If You're Not Living On The Edge, You're Taking Up Too Much Room.'
Founder Member: The Bad Parent Club!
As far as I can tell after a few minutes interrogating the I/Net you have the right bit.
I don't believe that there was a difference in those years of the 1.9D between the van and the MPV
http://seekpart24.com/valeo/clutch-kit-821426
http://www.ebay.com/itm/Clutch-Kit-Valeo...%26ps%3D50 and scroll to the bottom for compatible models
  • terryd999
There were slight changes to clutches around March 2000 based on small mods to the input shaft and pilot bore.
What's your RPO?
  • terryd999
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
