  • 6 Vote(s) - 3.33 Average
how to replace wing
does anybody know if i need to remove the bumper to replace passenger side wing on a mk1 belingo and is it easy to change thanks
Its a long time since I changed one but I think the front bumper was still in place. It was dropped down at the side needed to get at the bottom bolt of the wing hidden behind the end curved bit. I think there were two screws holding it which when removed and bumper pushed down revealed the bolt. The mudflap (if you have them) needed to be loosened off as they clamped to the wing with a screw into the body/wheel arch. Half a dozen bolts , disconnect the side repeated light and the wing falls off. ( as long as the bolts arent siezed in.)
Will need to change mine soon then I'll find out if my memory is failing or not. Confusedcratch:
[-] The following 2 users say Thank You to brodfather11 for this post:
  • dbutch, ron
thanks ill have a propper look at it when all the snow has gone it needs doing as its all rusting and falling to bits it strange the rest off the van is solid with no rust thanks again
I reckon it's a replacement wing if its rusty, berlingos are galvanised.
[-] The following 1 user says Thank You to steve valentine for this post:
  • ron
thanks mate it looks bad so i will be changing it thanks for the help lads
valeo alternator CL15 rebuild
Yesterday 07:08 PM
Unusual Braking Problem
Yesterday 06:33 PM
Yesterday 06:19 PM
oil Sump
Yesterday 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
Yesterday 04:34 PM
M59 1.4 Petrol question
14-03-2025 10:48 PM
14-03-2025 09:29 PM
» Replies: 27
14-03-2025 09:08 AM
Insurance Shocker !!!
14-03-2025 09:04 AM
13-03-2025 08:09 PM
