Hi folks
Just picked up my first Citroen its a multispace 2003 2l hdi
It drives normally and speeds along great apart from town driving at 1500rpm the car judders along in fourth gear so I have to change down to third and revs go up it goes away I've seen posts on other forums about this but no answer I know nothing about these engines as I've been driving vws
Thanks in advance
Jonny
Threads: 28
Thanks Received: 68 in 50 posts
Thanks Given: 29
Have a search on forum, I put it down to the gear ratios Being longer requiring you not change gear as soon
Threads: 2
Thanks Received: 6 in 1 posts
26-03-2013, 01:29 PM
(This post was last modified: 26-03-2013, 01:33 PM by robster.)
I would say you Air flow meter has had it.
I Had the same issue until last night, changed out my air flow and back to normal.
Threads: 29
Thanks Given: 67
20
1500rpm in 4th is a bit low. I never try 4th till I get up to 40mph.
Threads: 32
Thanks Given: 18
My trundles along in 4th at 1200 rpm quite nicely, and in 5th also.
Threads: 9
Thanks Received: 7 in 4 posts
Thanks Given: 9
Possible engine mounts worn.
Peugeot Partner 2.0hdi • Ford Focus RS • Porsche 944 • BMW 120d
Threads: 81
Thanks Given: 165
20
(26-03-2013, 07:23 PM)steve valentine Wrote: My trundles along in 4th at 1200 rpm quite nicely, and in 5th also.
I agree.
The 1.6 75 is pushing out max torque at 1500 so the ratios are no problem low roadspeed.
Mine will pull cleanly from 1000 in top and will trundle happily in 5th at 1200 with a loaded trailer.
Takes a lot of getting used to though-the Hdi was a real culture shock after my formative years spent with petrol engines and screaming Jap bikes with peak power at 7000+ and redlines marked at 10K....:eek:
I'd probably say the motor mounts are getting worn-like Nicosean cashpoint machines......
Threads: 2
Thanks Received: 2 in 2 posts
I've had my 2.0HDi from new (May 03), and I find it has always juddered at 1500 rpm, which equates to around 30mph in 4th, so just drop down to 3rd.
It could be down to the CO sensors as well.
A mate of mine and I both had Triumph Tiger 955's. His juddered and surged at low revs, mine didn't. There was nothing wrong with either of them though.
