  • 6 Vote(s) - 2.67 Average
Tyre/wheel swap
After my daughter wrote her (my old) car off i was wondering if i could put the wheels off a honda civic 2004 1.7 cdti tyre size 195 60H 15 on to my berlingo 2003 1.9 D van?
The tyres are brand new as she only had it serviced a few weeks previously seems a shame to waste them and some of mine need replacing soon.
If the wheels have the same hole distances and the offset i.e. the distance from the centre to the side is the same then it will probably work ok.
Bear in mind this info is worth the same as any other uninformed info on the internet.
Malc
Stupid computer!
Hi , Honda wheels may fit but as mentioned check offset also bolt spacings and center mounting hole , if unsure of honda wheels just use an alloy wheel selling website and dimensions should be shown, your van will have minimal clearance with 195s at rear inner wheelarch but spacers are a possibility, also use the correct bolts with alloys ,good luck.
I think the stud spacing on Honda is wrong for Citroen. 4x100 as opposed to 4x108, You could always get the tyres swapped to your rims.
Yesterday 05:06 PM
Yesterday 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
