  • 5 Vote(s) - 3.8 Average
vauxhall steel wheel
Hi does anyone know if a Vauxhall steel rim will fit on my berlingo...brought a tyre that's fitted to a Vauxhall 14 rim....
(26-01-2013, 12:49 PM)timo71 Wrote:  Hi does anyone know if a Vauxhall steel rim will fit on my berlingo...brought a tyre that's fitted to a Vauxhall 14 rim....
Highly unlikely due to the PCD of the holes and the blingo MK1/2 is fussy about offset too
Use the tyre and ebay the rim -theres a snow-tyre craze on at the moment.....
TBH I think we'd know if a run of the mill rim from Ford or
GM would fit a Citroen/ Peugeot as someone would have been and gone and done it!
Safe to say it's a no-no.
  • BerlingoHDI
Vauxhall is 4x100 berlingo is 4x108.
[-] The following 1 user says Thank You to steve valentine for this post:
  • ron
Cheers guys I'll get the tyre swapped to spare wheel rim ...
Today 12:33 PM
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
