Threads: 10
Thanks Received: 6 in 5 posts
Thanks Given: 5
I have a B9 1.6HDI with the EGS gearbox and stop start . Does anyone know how to get to the battery terminals? The battery has a plastic cover. Is it possible to charge the battery in situ? Thanks in anticipation. I believe this is a special battery.
Threads: 52
Thanks Given: 87
5
Good question and I'll be curious to see how one removes the battery in a B9. Had a look at mine yesterday and it looks like one must remove some electrical bits from the top of the battery case too.
Threads: 5
Thanks Received: 8 in 7 posts
I wouldn't bother taking the battery off to charge it, the alternator charges it whilst it's on the car so what's the difference? Use a good quality 3 stage charger.
That's my opinion, some will probably disagree.
The following 1 user says Thank You to Fletch for this post:1 user says Thank You to Fletch for this post
• ron
Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
31-01-2013, 10:20 PM
(This post was last modified: 31-01-2013, 10:23 PM by taxi.)
Good advice, Fletch, seems the best option-I would be too scared to even give somebody a jump-start using my car nowadays due to all the electronics etc.
Former 2011 Mk3 XTR owner
alut:
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Why would you charge it if its not broke?
I DO MISS MY BERLINGO
Threads: 10
Thanks Given: 5
You would charge it when it is broke!! and thanks Rustscrat for the info.
The following 1 user says Thank You to Jim7 for this post:1 user says Thank You to Jim7 for this post
• Rustscrat
Threads: 63
Thanks Given: 552
Should you not get at least 3 years out a modern battery?
