Threads: 9
Thanks Received: 2 in 2 posts
Thanks Given: 6
Hi All
I have recently bought a 2003 berlingo 1.9 diesel, it has covered 53k miles, last service was at 50k miles, but that was feb 2012. It has been parked up for quite a long time due to the previous owner erm.....having a long holiday from driving!, but apparently it was occassionally started up and had very short runs by another driver. I just wanted to know if it needs a service because its almost a year ago since the last one, even though its not done that much mileage during that time.
The car seems brilliant and runs well, starts up smoothly when its been used within a few hours or so, but seems to judder a bit on cold start ups,
thanks
Tommy
Threads: 67
Thanks Given: 1,045
Wouldn't hurt to change the oil and filter - be sure to use a compatible oil if it has a DPF.
Also, flush the brake fluid thoroughly - syringe out the reservoir, gently refill with new bottle of DOT4 fluid then bleed 100-150ml at all corners. You need to safety wire the load compensating valve open on the rear beam to be fully open when doing this. Remember to cut off the safety wire after! I can assure that if you don't, it makes for interesting brakes as the car will lock all four quite readily...
• ron
Threads: 9
Thanks Given: 6
Hi addo
many thanks for your advice
Tommy
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 166
21
Was it a holiday from driving or a holiday in one of her majestys hotels?
With an '03 keeping a Full Service History isnt really worth the expense anymore so some basic home maintenance will do just fine.
Like addo says, oil and filters plus the brake fluid as its had so little use
Threads: 20
Thanks Given: 2,126
18
[quote='evdama' pid='35541' dateline='1359485203']
Being of a curious nature,your question makes me want to ask if you are mildly interested,or have previous experience?:whistle::whistle:
Strawberry flavoured windows
Threads: 81
Thanks Given: 166
21
(29-01-2013, 08:35 PM)ron Wrote: [quote='evdama' pid='35541' dateline='1359485203']
Both Ron-a disturbing experience-delivering bulk animal feeds to a open prison farm on moorlands just outside Lancaster.
Surrounded by lags with pitchforks and no fences.
Wondering all the way home if there was a stowaway or two like in the Porridge film.
Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
Could have been much worse, evdama- they could have been The Wurzels, now that is scary.
Former 2011 Mk3 XTR owner
alut:
Threads: 81
Thanks Given: 166
21
(29-01-2013, 10:56 PM)taxi Wrote: Could have been much worse, evdama- they could have been The Wurzels, now that is scary.
:eek:
Threads: 67
Thanks Given: 1,045
What songs did they play?
Threads: 81
Thanks Given: 166
21
addo -you really dont want to know.
You were warned...
