  • 4 Vote(s) - 2 Average
Oil & filter change
Have read on this forum about changing engine oil when hot,even letting the engine run for 4 hours to get the oil hot. This sounds like overkill to me and I am sure garages don't do it. What is the difference in draining the oil after the car has been standing all night? More oil will have drained into the sump by then. This seems to be referring to the 1.6 HDI specifically. Any thoughts on the subject? Cheers.
I drain mine after a decent run(20miles min),take the filter out & leave draining overnight.I think the oil needs to be hot & "stirred" before draining.
I do the same with the transmission.(Apart from the filter bit)
Drains better. Always done it myself. But 4 hours is mad. As sed drive for 10-15mins
Using a flush on these engines is helpful I find, definitely when hot, but 4 hrs not easy to do !
(29-01-2013, 09:21 PM)Lighty Wrote:  Using a flush on these engines is helpful I find, definitely when hot, but 4 hrs not easy to do !
No need for a flush. All I do is throw a litre of a spare cheap oil is have to make sure and stuff at the bottom is gone.
I took mine in for a service today -they had it for 3 hrs.
As I drove it out I noticed the temp guage at its normal 85 degrees ,so the dealerships certainly drain the engines hot.
But the 4 hrs really is bullsh.
Once the thermostat has opened and the fan kicks in
it wont get any hotter anyway
Idling for 4 hrs will glaze up the top end and fill up the DPF.
But like ron says you need all the soot and sludge stirred up to let it out with the oil.
Or do both- let the bulk of it out hot then leave overnight to get the drips out
I let mine drain overnight from a warm engine. I always wonder if there's a puddle left in the sump though. The cheap oil is a good idea, or are we being a bit fanatical lol
Hdi owners need to be fanatical!
Im not even sure cheap oil is a good idea for more than a few minutes
  • ron
Flushing is to be done at your peril, remember that all the sludge traps in the engine will be wanting to release their hoard.... anyone fancy some new shell bearings putting in on the weekend.
Just my views, you choose for yourself.
I mean when its almost drained pour in a litre. And just leave it run through
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
