Threads: 80
Thanks Received: 392 in 335 posts
Thanks Given: 164
18
The drives wet cold and covered in sawdust so im not scrobbling around under there today to have a peek, but I was just pondering-if a van has ABS will it have (or need) a valve?
Threads: 67
Thanks Given: 1,045
FWIW my Pug 605s have a compensating valve and ABS.
Threads: 80
Thanks Given: 164
18
Thinking more as I should have done -yes it will otherwise the abs would be working overtime
Threads: 67
Thanks Given: 1,045
In most FWD applications - passenger cars especially - the rear brakes do SFA until you get a good load in the boot and rear seats. I think this is part of the reason people can drive a PSA car with obstructed rear flexi hoses and be unaware of it.
Threads: 80
Thanks Given: 164
18
My C15's brakes were so bad the only thing they would stop was your heart-I clipped the valve permanently open but it made only a minor difference.
• andy-womble
Threads: 5
Thanks Received: 44 in 35 posts
Thanks Given: 4
Load compensator valve is located on the drivers side of the rear subframe, with a spring running to a bracket on the trailing arm just behind the torsion bar mounting. I just bent the bracket round slightly when I lowered mine.
Threads: 80
Thanks Given: 164
18
(30-01-2013, 08:47 PM)ron Wrote: (30-01-2013, 11:28 AM)evdama Wrote: My C15's brakes were so bad the only thing they would stop was your heart-I clipped the valve permanently open but it made only a minor difference.
Thanks Morris.:lol::lol:
still not Elf-y:whistle:
