  • 4 Vote(s) - 2.75 Average
timing belt
Have a 2002 berlingo 19d van, last timing belt changed at 92000 and now has done 147000
Any 1 know what miles between each change
[-] The following 1 user says Thank You to forapound for this post:
  • addo
less than that!
The interval is 80,000 miles on the 1.9D
(30-01-2013, 03:28 PM)Opensauce Wrote:  The interval is 80,000 miles on the 1.9D
So I'm good for about another 20000
Thank you
Haynes suggest 40,000. I'd err on the side of caution myself and get it changed reasonably soon.
(30-01-2013, 04:29 PM)forapound Wrote:  So I'm good for about another 20000
Thank you
Yes, 80K is the interval but one would hope you have good evidence the belt was changed at that mileage. I don't know what other parts should be changed at same time, probably tensioner & waterpump so worth a check.
Thank you
It's going through the mot in 2 week so will probs need work done to it to pass so will get the belt changed and what ever else needs done
Cracking engine them 19d
Hi, I have just bought a MK1 with 100,000 on the clock...the timing belt was changed at 70,000 miles according to what is written on the engine...I am always cutious and was wondering what time interval the water pump should be replaced,to save destroying the engine.Any advice would be appretiated,thank you.
If the MOT is due then just remember that when they do the emmissions test they rev the nuts off it. They will accept no reposibility is it breaks and wrecks your engine.
We have always changed our timing belts much sooner than recommended. I do ours on the DW8 engine at 50000mile intervals. It may seem a tad expensive but it is cheaper than a knackered engine. If I was buying second hand I would change it straight away regardless of what has been said by the previous owner.
Peter
[-] The following 2 users say Thank You to Romahomepete for this post:
  • RolyG, ron
Same here changed as soon after purchase as possible
Sent from my GT-I9300 using Tapatalk
2004 1.9D Multispace/Budget crew cab work van!
[-] The following 1 user says Thank You to chronyx for this post:
  • RolyG
M59 1.4 Petrol question
Today 08:47 AM
Today 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
Yesterday 06:47 PM
Last Post: deejay_xb
Yesterday 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
Yesterday 01:48 PM
Unusual Braking Problem
Yesterday 07:52 AM
valeo alternator CL15 rebuild
Yesterday 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
15-03-2025 04:34 PM
