  • 13 Vote(s) - 2.38 Average
Mains powered tyre inflator
Having struggled with various foot pumps/12v pumps/those chargable multi pump/jumper packs over the years, I've finally found something that is capable of doing the job.
With 3 sometimes 4 vehicles in the family it's a constant battle to maintain their tyre pressures.
I eventually bought a RING Automotive RAC750 230V Mains Powered Air Compressor. It's not perfect: The pressure gauge is about as useful as our current PM and you will struggle to pack the mains cable away. However it does come in a handy storage bag and does the job very well.
The valve is a bit tight at the moment but I'm sure it will loosen up. I use it in conjunction with the RACE X PROFESSIONAL TYRE PRESSURE GAUGE which is also superb. One van, one motorbike and a car all done in well under 10 minutes.Big Grin
I don't work for Ring I'm just wanted something to get the job done quickly and efficiently.
[-] The following 3 users say Thank You to RocketVANman for this post:
  • evdama, Ol'Jeffers, taxi
Whats the max pressure it will do
300psi but there's redline between 200 and 300??
[-] The following 1 user says Thank You to RocketVANman for this post:
  • j90xxx
(31-01-2013, 01:59 PM)RocketVANman Wrote:  300psi but there's redline between 200 and 300??
Ive actually managed to fit a tyre to a rim using a single barrel footpump (more luck than judgement and anyone else would have used tyre levers)
So this would possibly be suitable for such a job??
I presume you needs lots of air to put a rim on a tyre. I think it's marked that it can blow a tyre up in 2 minutes (i think that was the figure I saw).
It's pretty powerful I only had to use it in short burst. My bike tyres were the worst they needed over half a bar each and it didn't even break into a sweat.
I'll come back in a year and give a long term test.
They also do a megga 12v version that is capable of 4 x 4 tyres with ease apparently. Try the Ring RAC700 or RAC900 if you want more power but they're both 12V
I bought a compressor with a 50ltr receiver for £150 years ago which is big enough for spraying,applying waxoyl & all sorts of other mechanical mischief.It seemed a lot at the time but I'm glad I bought it.(I have even test run my brothers'steam locos prior to steaming)
[-] The following 2 users say Thank You to ron for this post:
  • andy-womble, evdama
(31-01-2013, 08:16 PM)ron Wrote:  I bought a compressor with a 50ltr receiver for £150 years ago which is big enough for spraying,applying waxoyl & all sorts of other mechanical mischief.It seemed a lot at the time but I'm glad I bought it.(I have even test run my brothers'steam locos prior to steaming)
With Ron on this one, bought similar off e-bay a few years back. Spray 150ft of fence panels every 2 or 3 years, tyre inflation, unblocking pipes on the pond filtration, powering spray equipment etc etc.... limited only by your own imagination...
The words "ron" and "mischeif".....
Why am I not surprised.
[/quote]
Evil he who evil thinks.:eek:
Blow-Up-Doll.....
Today 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
