  • 13 Vote(s) - 3.69 Average
Key fob programming help
I've recently bought a spare key for an '05 multispace but the remote central locking doesn't work with it.
I've read around and there's a few guides on how to program it to work but no matter what I try the new key just won't bind. All instructions I've found say you need to repeat the steps for each fob but I've deliberately not done the steps for the old fob and it still works so I'm guessing it's not even going into programming mode.
Any ideas on exactly what the correct procedure should be? Or can this only be done with a lexia 3?
Have a read of this. Confusedtudy: Confusedalut:
.pdf   key fob syncing2.pdf (Size: 12.65 KB / Downloads: 781)
[-] The following 3 users say Thank You to Rustscrat for this post:
  • Ol'Jeffers, RolyG, ron
Thanks for this post.
let's try
My remote key didn't seem to work, when I opened it up the microswitch had come off. New one bought for £1.50 and soldered on in seconds and all working properly now!!
(19-10-2013, 08:46 PM)Waynejohnson Wrote:  My remote key didn't seem to work, when I opened it up the microswitch had come off. New one bought for £1.50 and soldered on in seconds and all working properly now!!
Which microswitch was that?
Similar (I think) problem for me. New key fob, put existing transponder inside, remote lock/unlock works but engine won't start. Hopefully now I've posted I can download the above instructions...
Wink
Thectransponder is probably too far away from the sensor.
Have you tried removing transponder placing next to sensor and then trying to start the car,?
Fixed - problem mainly due to me being an idiot. I'd transferred a new key to the new fob, plus the original circuit board. What I hadn't swapped was the little black transponder from the corner. Once I swapped that too everything then worked.
Ta for the advice though!
Hi sorry to drag up an old post but i need to post a reply to download the document, i recently bought a second hand key fob from ebay for my berlingo, i swapped the back over and it starts but cant get the fob to program to the car, the circuit board inside does look different to the old one, will the different type still be compatible?
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
