Mpg Berlingo multispace 1.6hdi diesel
Threads: 2
Thanks Given: 6
Hi
I have just bought my 2006 Berlingo and was on the assumption that it would do 50mpg?
Its looking more like 42.00 pr gallon, I am a bit dissapointed because my Renault Clio did 50 something a gallon.
I think the tank takes 13gallon. I would be surprised if the 1.9 does more!
Threads: 9
Thanks Received: 28 in 21 posts
Thanks Given: 18
I've just bought a 2007 (56 reg) 1.6 Hdi. I've fuelled it 4 times, and done about 1300 miles, but so far I am averaging roughly 55 mpg. Early days yet, though.
Threads: 147
Thanks Given: 263
11
You should check things like tyre pressure, the air filter, a/c on(?), these things will have an effect on your MPG.
Threads: 9
Thanks Given: 18
Quote:You should check things like tyre pressure, the air filter, a/c on(?), these things will have an effect on your MPG.
And if you want a longer list of ways to improve MPG, you might find this page helpful:
http://ecomodder.com/forum/EM-hypermilin...riving.php
Most of them are over the top, but there are some helpful hints there.
Threads: 80
Thanks Given: 25
remember your clio is a much smaller car, less wind resistance etc etc and it depends where and how you drive your berlingo. not sure if yours is mk 2 or mk 3 , mk 2 is slightly better as one would expect....its not so large. I get on average 47 ish up and down a 1000ft mountain side, on a dual carriageway i get 50. as long as i`m not racing........mk 3......
and as stated tyres/ fuel/ serviced regularly all help.
AND mainly a light right foot...........
The following 1 user says Thank You to pch for this post:1 user says Thank You to pch for this post
• Dizzydi
Threads: 47
Thanks Received: 63 in 49 posts
Thanks Given: 48
My 1.6HDI does 52-55 most of the time.
The following 1 user says Thank You to eame64 for this post:1 user says Thank You to eame64 for this post
• Dizzydi
Threads: 32
Thanks Given: 18
Just done 510 miles in my MK1 2.0HDI 95% motorway sticking to 70, got 48.5 mpg
Threads: 3
Thanks Received: 7 in 6 posts
Thanks Given: 3
25-03-2011, 03:31 PM
(This post was last modified: 25-03-2011, 03:40 PM by steve.)
(24-03-2011, 10:53 AM)Dizzydi Wrote: Hi
Hi Dizzydi,if you have the 1.9 engine fitted 42.0 is about right.A friend of mine was a fireman,they ran the 1.9 alongside the 2.0hdi and the 2.0 hdi consistently returned high 40's while the 1.9 were usually under 40 mpg.I myself have run the 2.0 hdi and 50+ was normal.At present i have a 2008 1.6 vtr,this struggles to achieve 50 mpg,it's usually high 40's.As someone else mentioned tyre presures are critical as is servicing.Also the Michelin energy tyres if fitted will give you extra mpg i have found.
The following 1 user says Thank You to steve for this post:1 user says Thank You to steve for this post
• Dizzydi
Threads: 63
Thanks Given: 410
25-03-2011, 04:10 PM
(This post was last modified: 25-03-2011, 04:14 PM by andy-womble.)
Steve, Don't know what the connection is between being a fireman and owning/running a Berlingo but taking Dizzydi's point, just think of the size difference between a fart-box of a Clio and a sizeable muscle motor like a Berlingo.
Bound to use just a little bit more fuel I would have thought....
P.P.S. We went from a 1.9D 306 Hatch to a 2.0HDI Berlingo and I think the 'lingo is better on fuel economy if I keep control of my right foot. I still love the old 1.9 non-turbo'ed 306
Threads: 3
Thanks Given: 3
27-03-2011, 04:55 PM
(This post was last modified: 27-03-2011, 04:59 PM by steve.)
(25-03-2011, 04:10 PM)andy-womble Wrote: Steve, Don't know what the connection is between being a fireman and owning/running a Berlingo but taking Dizzydi's point, just think of the size difference between a fart-box of a Clio and a sizeable muscle motor like a Berlingo.
I wasn't trying to make a connection to a fireman,merely trying to give a comparison from someone who drove both vehicles on a regular basis.So was able to give a knowledgeable comparison.
1.6hdi starting problem
Yesterday 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
