  • 6 Vote(s) - 3.5 Average
heater matrix pipes
Hi All.
i have a misty windscreen when i first start to drive does clear in the end, i had a look up from the drivers footwell and can see the pipes that supply the matrix has some pink crusty stuff. obviously it looks to be leaking from there has anyone had this problem? has antone got a diagram for the matrix and piping when it comes into the bulkhead?
The heater matrix are well known for leaking, it may be that and the coolant running down the pipes, evaporating and leaving the coolant crystallising.
What model have you got ?.
HI. i have a 1999 t reg 600 1.9d.
It's probably the plastic pipe inline union just atop the matrix itself - a marvellously poor bit of engineering that distorts with time and heat to allow leakage.
can i just change the pipes or is the matrix apart of it?
is it a complete dash out job?
I'd guess it's a dash out job. Haven't done a Berlingo but the Xantia uses that same matrix with the same leaks.
  • amtech
I have the same problem in my MkI blingo, very bad coolant smell when I turn on the fan with hot setting. I wish I knew how to repair it.
Rad weld. mines very small at the moment so could be an option.
Here you are.Confusedalut:
.pdf   mk1 heater n hoses2.pdf (Size: 56.03 KB / Downloads: 88)
[-] The following 4 users say Thank You to Rustscrat for this post:
  • amtech, avocado, Bellendio, ron
Rustscrat thank you very much, just what i was looking for.
[-] The following 1 user says Thank You to amtech for this post:
  • Rustscrat
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
