what a dummy I am
Threads: 80
Thanks Given: 25
24-03-2011, 07:04 PM
(This post was last modified: 24-03-2011, 07:40 PM by pch.)
I actually called my self something far worse......begining with f idiot ....
I filled my diesel up yesterday at petrol station......and can you guess...
put bloody petrol in didnt I....
spluttered to a stop today....
AA out under Citroen assist policy .....
Mechanic said can I see your last fuel receipt....
prat prat prat.....
towed to local garage after AA man said under Citroen assist policy he has to notify Citroen, My local garage said confirm with Citroen dealer , they said they prefer car to go to them, with persistence they agreed my warranty still ok going to local garage aslong as receipt states oem parts are fitted.
fool I am
and probably a few pounds lighter.....in my wallet.
What a day...
Pete
ok pk what have I knackered ?
Threads: 25
Thanks Received: 47 in 29 posts
Thanks Given: 23
I am sure you are not the first to do that and you sure will not be the last hopefully you will not have done too much damage ,how far did you get ?
Threads: 80
Thanks Given: 25
ABOUT 30 miles, tank was half full of diesel before filling with premium unleaded.....the best...ha ha
Threads: 9
Thanks Received: 28 in 21 posts
Thanks Given: 18
Sorry to hear it, Pete.
We've had our current Berlingo for a couple of months now. It's our first ever diesel vehicle. And both my wife and I are terrified that one day this is going to happen to us. It's only been fuelled four times, and so far, so good, but . . . .
Last time I checked, it wasn't possible to buy a Fuel Angel for a Mk 2 Berlingo. And the petrol cap in the Mk 2 is also designed in such a way that it isn't actually very easy to stick in a DIY note that says "DIESEL".
Threads: 80
Thanks Given: 25
mine is black inside cap, with big sign saying diesel and the pump pipe is normally black BUT i just stuck a green pipe in....god knows why.
Threads: 32
Thanks Given: 18
24-03-2011, 10:50 PM
(This post was last modified: 24-03-2011, 10:51 PM by steve valentine.)
If you run it till it conked out, it's gunna be a big bill I'm afraid!
Depending on what damage is done, it can cost upto £5000!
Or maybe you'll be lucky and it won't cost more than £200 :p
It can kill injectors, diesel pump, the catalytic converter.........
I really hope it's a cheap fix for you mate!
Threads: 3
Not realy a big problem. Just get hold of a big container or two. Also some of that clear plastic tubbeing the sort you use for syphening your home brew.
Feed one end of the pipe into your fuel tank, as far as it will go. Then suck until it flows (try not to get any in mouth) then feed other end into container. As long as the container is at a lower level than fuel tank it will empty fairly quickly.
Once you have worked out that most of the petrol is out. Then start pouring some diesel into tank. It wont hurt if there is a slight petrol mix.
For good messure take the fuel filter out and drain out the petrol from the bowl.
Jobs a good one.
Threads: 52
Thanks Given: 87
5
25-03-2011, 05:31 AM
(This post was last modified: 25-03-2011, 07:23 AM by 3rensho.)
Sorry to hear that Pete. Hope all is well after the repair and that it is cheap. Having driven petrol cars all my life I have a fear of doing the same thing sometime.
Threads: 80
Thanks Given: 25
cheers guys, lets hope it s a cheap bill. Garage are doing it today so hopefully let you know later?
Threads: 63
Thanks Given: 410
(24-03-2011, 11:44 PM)ferrous wheel Wrote: Not realy a big problem. Just get hold of a big container or two. Also some of that clear plastic tubbeing the sort you use for syphening your home brew.
Jobs a good one.
Sorry to disappoint you, not quite as simplistic as that when quite high concentrations of petrol are present in the fuel mix. In this case sounds like a potential 50:50 mix and having driven until it stopped could be quite involved and heavy on the wallet.
2015 Berlingo van for sale
Last Post: eddyale
Today 06:47 PM
Last Post: deejay_xb
Today 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
Today 01:48 PM
Unusual Braking Problem
Today 07:52 AM
valeo alternator CL15 rebuild
Today 07:49 AM
Yesterday 06:19 PM
oil Sump
Yesterday 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
Yesterday 04:34 PM
M59 1.4 Petrol question
14-03-2025 10:48 PM
14-03-2025 09:08 AM
