Sliding Door
Threads: 15
Thanks Received: 26 in 17 posts
Thanks Given: 25
Location: Blairgowrie, Perth And Kinross, United Kingdom
Hi folks, does anyone know if the cable that unlatches the door when it is in the open position can be adjusted. Over the last few weeks I have been having a bit bother when trying to close the door, I have to push the door very slightly towards the rear in order to unlatch it. Might be the latch that is worn but my thoughts go with the cable. Van has only covered a genuine 18,000miles so wouldn't have thought it would be worn. Any help or advice will be gratefully received. Thanks for taking the time to read,
Dave.
Threads: 2
Thanks Received: 19 in 19 posts
Thanks Given: 596
(03-02-2013, 06:16 PM)tanto Wrote: Hi folks, does anyone know if the cable that unlatches the door when it is in the open position can be adjusted. Over the last few weeks I have been having a bit bother when trying to close the door, I have to push the door very slightly towards the rear in order to unlatch it. Might be the latch that is worn but my thoughts go with the cable. Van has only covered a genuine 18,000miles so wouldn't have thought it would be worn. Any help or advice will be gratefully received. Thanks for taking the time to read,
Dave. Try a littel Oil or grees on the latch it fixed mine.
The following 1 user says Thank You to RolyG for this post:1 user says Thank You to RolyG for this post
• tanto
Threads: 15
Thanks Given: 25
(03-02-2013, 10:22 PM)RolyG Wrote: (03-02-2013, 06:16 PM)tanto Wrote: Hi folks, does anyone know if the cable that unlatches the door when it is in the open position can be adjusted. Over the last few weeks I have been having a bit bother when trying to close the door, I have to push the door very slightly towards the rear in order to unlatch it. Might be the latch that is worn but my thoughts go with the cable. Van has only covered a genuine 18,000miles so wouldn't have thought it would be worn. Any help or advice will be gratefully received. Thanks for taking the time to read,
tried that yesterday, didn't make any difference. Will maybe give it a good clean and lube later this week before trying anything else. Just feels as if the cable could do with tightening slightly.
Threads: 15
Thanks Given: 25
Well I thought someone here would know the answer to my simple query but apparently not. Ok I suppose I will have to just jumpin at the deep end and start stripping the door at the weekend and see what I find. Thanks anyway for looking.
Dave
Threads: 24
Thanks Received: 52 in 44 posts
Thanks Given: 9
(05-02-2013, 08:21 PM)tanto Wrote: Well I thought someone here would know the answer to my simple query but apparently not. Ok I suppose I will have to just jumpin at the deep end and start stripping the door at the weekend and see what I find. Thanks anyway for looking.
Dave Hi Dave, take a look at my How To thingy on repairing the pin in the sliding door. From memory there are two cables controlled by the outer handle. One can be adjusted. When I put handle back it wouldn't open (or close I can't remember!), so adjusted the cable.
http://www.berlingoforum.co.uk/showthread.php?tid=4650
Threads: 15
Thanks Given: 25
(05-02-2013, 08:32 PM)Modmytop Wrote: (05-02-2013, 08:21 PM)tanto Wrote: Well I thought someone here would know the answer to my simple query but apparently not. Ok I suppose I will have to just jumpin at the deep end and start stripping the door at the weekend and see what I find. Thanks anyway for looking.
Hi Modmytop, thanks for the reply and your "how to". I will have a look at the weekend and see what is required. Dont fancy taking the door off but if push comes to shove then hey-ho, thats what I'll have to do.
Thanks again ,
Dave.
Threads: 24
Thanks Given: 9
(05-02-2013, 09:55 PM)tanto Wrote: (05-02-2013, 08:32 PM)Modmytop Wrote: (05-02-2013, 08:21 PM)tanto Wrote: Well I thought someone here would know the answer to my simple query but apparently not. Ok I suppose I will have to just jumpin at the deep end and start stripping the door at the weekend and see what I find. Thanks anyway for looking.
Thanks again ,
Dave. You should be able to get at the cables without taking door off. When I fixed my floppy door handle (a Berlingo problem) I followed the Haynes Manuel. If you can get the plastic bolts (?) off then yes you will not have to take door off.
The following 1 user says Thank You to Modmytop for this post:1 user says Thank You to Modmytop for this post
• tanto
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
